Open Tx 2.2.4
Open Tx 2.2.4
Vyšla verze 2.2.4 + Fw
Re: Open Tx 2.2.4
Diky za upozorneni, koukal jsem ze zmen nic moc
Re: Open Tx 2.2.4
Main changes since 2.2.3
Multiprotocol: updated to match 1.2.1.63 (thx MRC3742)
Taranis: fix an issue where changing max baud could turn external module on
Taranis: remove Alt from top bar display in FAI mode
Horus: fix plane and glider wizard when no motor is selected
FrSky: fix ModelID unduly checked in D8 mode
FrSky: support Neuron ESC telemetry
Sky9X : add Flex R9M support
Crossfire: add vario sensor
Crossfire: raw CRSF telemetry data can be mirrored on AUX serial port
LUA: fix an issue where sportTelemetryPush() was not working when crc is 0x7D or 0x7E
LUA: add telem1 to telem32v
LUA: add lua mixers outputs
Companion: fix negative gvar precision (thx elecpower)
Companion: add mouseover tool tips to label fields with context menus (thx elecpower)
Companion: fix special function Inc/Dec Gvar (thx elecpower)
Companion: better multiprotocol name handling (thx MRC3742)
Companion: GPS format matches radio choice (thx elecpower)
Když musíš, tak musíš....
Re: Open Tx 2.2.4
Já jsem aktualizoval hlavně z důvodů Neuronu, a ta telemetrie SBEC je perfektní
Taranis X9E
